on max problem
(Topic created on: 03-04-2019 04:27 PM)
mridu
Galaxy On
native video call image quality is too dark(on max after oreo update & feb ptch update)& vry poor...battery also drain fast...pls solve this prblm
7 Comments
Rishikanji
Galaxy On
yes battery draining problem is soo much..
INDIANCYBER
Galaxy On
oh no
INDIANCYBER
Galaxy On
yes
admin_
Galaxy On
Thank you for sharing your concern. We apologize for the inconvenience caused to you. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
mridu
Galaxy On
oh mr. admin khud hi check kar lo....or problem fix karo....nahi to wapas nogut 7.0 de do...o acca h
mridu
Galaxy On
or 8.0 p extra kya h...sirf bugs n bugs
Not applicable
Galaxy On
worst update from Samsung...it would be better if you give fota update soon. Otherwise in the present scenario of poor quality updates by Samsung you must give an option to go back to factory version of Android.
