Call problem
(Topic created on: a month ago)
HDC
Sometimes I have phone problem that when I call someone and end but itcamt end when I trying to call again it shows you first end first call and then make new call but in my screen its didn't calling it just like bugs there I need to restart phone eveytime which cause irritaion for me eveyrime fix this issue for my samsung s 25 ultra
cs_member10
Dear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application >> tap on Support >> tap on Send feedback >> Tap on Send icon >> select the appropriate category y >> type your query and tap on send).
