Need Help
(Topic created on: 11-30-2019 03:10 PM)
27GautParacom
Is fingerprint scanner is visible on the screen like this.
Please comment with model number if visible capture a image
9 Comments
joydir
h
Sidhabhi
27GautParacom
but I don't think so it visible for all companies like one plus ,vivo and oppo
Sidhabhi
Can't say anything about those devices..
Foxhound
Because they use non optical fingerprint sensors which capture fingerprints via an uds camera. Unlike optical which emit ultrasonic signals. So in companies like oneplus and vivo that sensor is not visible easily.
Sidhabhi
Absolutely correct..their fingerprints are also visible but at extreme brightness..also difference in display quality is another factor..
Foxhound
Yes under bright sunlight it is easily visible..
Gaurav73040
under bright sunlight it is visible
27GautParacom
it is visible for note 10
