Network problem
(Topic created on: 2 weeks ago)
ankitvijay
Beginner Level 3
Network problem for calling
5G network
3 Comments
Firoz077
Please check your SIM Network and Telecom operators
shivamtayal
Facing same
cs_member10
Dear Samsung Member,
● Kindly check the device in different locations/network coverage areas.
● Check Mobile Network: Settings> Connections>Mobile networks> Network mode> Select 5G/LTE/3G/2G (auto connect).
● Check Network Operator: Settings> Connections> Mobile networks> Network operators> Select automatically.
● Kindly check the same SIM card in another phone or another SIM card in the same phone to verify the issue.
● Kindly try to contact the service provider once.
● Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
● You can reset your device by following the steps from the below link.
In case the issue still occurs, kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
