Notification Panel or Control Panel Issue
(Topic created on: 4 weeks ago)
nikhilpl
Why the notification background color of Swiggy and youtube is more transparent then other this Also applies in Call notification, Airtel application notification. I don't use any notification theme, But why this happens ?
 Device - S24 Snapdragon Varient
 Currently on One UI 9.0, facing this issue from One UI 8.5
 Is it any glitch or it was made like this ?
3 Comments
lavenderrr
I dont think so thats a glitch. i also have same phone variant and update. and its been same as you. not all notifications are equally transparent.
nikhilpl
Before it was happen when we use notification panel theme via Theme Park module then if we unapply the theme then it gone, but now it not going anywhere
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application >> tap on Support >> tap on Send feedback >> Tap on Send icon >> select the appropriate category y >> type your query and tap on send).
