S23Fe Camera Problem after update
(Topic created on: 05-06-2025 08:47 PM)
Wall-ee
Kisi ne Notice kara , camera quality One Ui 7 ke baad thodi down ho gyi, Color shift dekne ko mil rha hai...
#sasmung #camera #galaxy
4 Comments
goodthings
goodthings
Your's most welcome to here.
harshit24012005
cs_member10
Dear Samsung Member,
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
