Battery drain
(Topic created on: 09-28-2023 07:27 PM)
vkeshav
Wearables
Hi
I am facing issues with my watch 4 .The battery drains out too fast. Are you'll facing the same issue. I am experiencing this after the recent update
5 Comments
Beekaji
Wearables
Not only one there are lot of bugs
cs_member10
Wearables
Dear Samsung Member,
1-Kindly open the Apps screen on a watch.
2-Swipe the screen and tap on General.
3-Reset.
And also share reports of the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
vkeshav
Wearables
Tks will try
Not applicable
Wearables
Just reset it once. Mine is working very good after the update
iamrohitkm
Wearables
Wait for some more time as the new update is very huge and battery capacity is less it will take some time for the new OS to get set with battery. Mine also same issue. I will wait for some more days.
